02-24-2007 01:02 AM - edited 03-13-2019 03:57 PM
I have installed Unity on MCS(IBM X345, 2 hard drives) W/RAID 0+1.
After I switched hard drives( HD0-->slot1, HD1-->slot0), power on, it shows "... reconfigure...." choose " set as vendor default"
Problem: OS can't boot up.
Any suggestion for that? I do believe it is array/hard drive setup issue.
Thanks.
02-24-2007 07:02 AM
swapping drives on the same server is never a good idea. If you re-configured it to vendor Default, then the RIAD has been rebuilt from scratch and therefore you must have lost all the content. When you want to replace a drive, you should only remove one at a time, and never swap/change both the drives at the same time.
02-25-2007 10:56 PM
Thanks again mchandak, you are very helpful.
Problem fixed. Fortunately I didn't rebuild the RAID,I just placed back the HDDs and copy the info. to RAID. HDDs was recognized and OS is running.
