MeetingPlace Express 2.0 can't dialout using SIP trunk
Hi guys,
I have a problem with meetingplace express 2.0. I can't dial out. Am using a SIP trunk with CUCM 7.0, yet I have followed all the instructions as per the guides. Find below my logs for eventlog -T -t
12/21 16:56:39.50    INFO rvsip_call.cc:1764 (ID=0x5) (DN=,P=249) SIP: Placing outdial.
12/21 16:56:39.50    INFO rvsip_call.cc:1778 (ID=0x5) (DN=,P=249) SIP: MP RTP:  172.29.104.5:18266
12/21 16:56:39.50    INFO rvsip_call.cc:1781 (ID=0x5) (DN=,P=249) SIP: MP RTCP:  172.29.104.5:18267
12/21 16:56:39.50    INFO rvsip_call.cc:1847 (ID=0x5) (DN=7777,P=249) SIP: To address=To:sip:7777@172.29.104.2:5060
12/21 16:56:39.50    INFO rvsip_call.cc:1900 (ID=0x5) (DN=7777,P=249) SIP: From address=From:"Cisco Unified MeetingPlace " <sip:4727@172.29.104.5:5060>
12/21 16:56:39.50    INFO rvsip_call.cc:4445 (ID=0x5) (DN=7777,P=249) SIP: --CreateSDPBody
12/21 16:56:39.50  RSCMGMT-INFO utilrscmgmt.cc:953 (2988) RscMgmt::allocateSched [3,1,1]
12/21 16:56:39.50  RSCMGMT-INFO utilrscmgmt.cc:982 (2988) Exceed # Config Premium:  [25,25;25,277], [25,0,0,25;0,0;0,0;0,0,0,0]
12/21 16:56:39.50  RSCMGMT-INFO utilrscmgmt.cc:953 (2988) RscMgmt::allocateSched [2,1,1]
12/21 16:56:39.50  RSCMGMT-INFO utilrscmgmt.cc:953 (2988) RscMgmt::allocateSched [1,1,1]
12/21 16:56:39.50    INFO rvsip_call.cc:4367 (ID=0x5) (DN=7777,P=249) SIP: --CreateOfferSDPBody
12/21 16:56:39.50    INFO rvsip_call.cc:4644 (ID=0x5) (DN=7777,P=249) SIP: Setting millisecondPacketSize=20
12/21 16:56:39.50    INFO rvsip_call.cc:1968 (ID=0x5) (DN=7777,P=249) SIP: Destination= To:sip:7777@172.29.104.2:5060, index_sip_active_CM = 0
12/21 16:56:39.50    INFO rvsip_call.cc:2446 (ID=0x5) (DN=7777,P=249) SIP: --HandleCallStateChange
12/21 16:56:39.50    INFO rvsip_call.cc:2448 (ID=0x5) (DN=7777,P=249) SIP: Handling :  State=Inviting(1) Reason=Local Inviting(0)
12/21 16:56:39.51    INFO rvsip_call.cc:2446 (ID=0x5) (DN=7777,P=249) SIP: --HandleCallStateChange
12/21 16:56:39.51    INFO rvsip_call.cc:2448 (ID=0x5) (DN=7777,P=249) SIP: Handling :  State=Proceeding(13) Reason=Remote Provisional Resp(26)
12/21 16:56:39.51    INFO rvsip_call.cc:2448 (ID=0x5) (DN=7777,P=249) SIP: Handling :  State=Disconnected(7) Reason=Server Failure(12)
12/21 16:56:39.51    INFO rvsip_call.cc:2448 (ID=0x5) (DN=7777,P=249) SIP: Handling :  State=Terminated(9) Reason=Call Terminated(19)
12/21 16:56:39.51    INFO rvsip_call.cc:2597 (ID=0x5) (DN=7777,P=249) SIP: rscMgmt: deAllocate audio, 1
12/21 16:56:39.51  RSCMGMT-INFO utilrscmgmt.cc:1036 (2988) RscMgmt::deAllocateSched [1,1,1]
12/21 16:56:39.51    INFO rvsip_call.cc:2609 (2990) Test call disconn, reDialPSTN = 249, PSTN = 249
12/21 16:56:39.51    INFO cca_call.cc:973 (ID=0x5) (DN=7777,P=249) SIP: --HUPIPCall
12/21 16:56:39.51    INFO cca_call.cc:975 (ID=0x5) (DN=7777,P=249) SIP: MeetingPlace Disconnecting. IRC=18266 PSTN=249 Unit=0
12/21 16:56:39.51    INFO cca_call.cc:989 (ID=0x5) (DN=7777,P=249) SIP: MP Rqst. Msg=5 CPerr=0 SeqNum=0x500
12/21 16:56:39.52    INFO cca_call.cc:1005 (ID=0x5) (DN=7777,P=249) SIP: MP Resp. Msg=5 CPerr=0 SeqNum=0x500
12/21 16:56:39.52    INFO rvsip_call.cc:59 (ID=0x5) (DN=7777,P=249) SIP: sipEndCall
12/21 16:56:39.52    INFO rvsip_call.cc:1462 (ID=0x5) (DN=7777,P=249) SIP: Reinvite is Not pending
12/21 16:56:39.52    INFO cca_call.cc:118 (ID=0x5) (DN=7777,P=249) SIP: --end_call
12/21 16:56:39.52    INFO cca_call.cc:146 (ID=00) (DN=,P=0)  : Call ended
12/21 16:56:39.52    INFO rvsip_call.cc:2629 (ID=00) (DN=,P=0)  : Call ended
12/21 16:57:28.11    INFO cca_call.cc:305 (3032) --PlaceIPCall
12/21 16:57:28.11    INFO cca_call.cc:315 (3032) MeetingPlace outdial. Phone#=7777 IRC=18014 PSTN=249 Unit=0
12/21 16:57:28.11    INFO rvsip_call.cc:1742 (3032) --PlaceSIPCall
12/21 16:57:28.11    INFO cca_call.cc:62 (3032) --new_call
Any help will be appreciated!
522
