MeetingPlace Express strange problem!
Environment:
MeetingPlace Express 1.1.1.11
CallManager 4.1(3)sr2
Voice Gateway 1: 2821 (c2800nm-advipservicesk9-mz.124-4.T.bin) + VIC2-4FXO
Voice Gateway 2: 2621XM (c2600-advipservicesk9-mz.123-14.T5.bin) + NM-2V + 2* VIC-2FXO
VG1 connect to CallManager using H.323, VG2 connect to CallManager using MGCP
MeetingPlace Express connect to CallManager using H.323.
Problem:
When dial-in from PSTN to VG1 and VG2, both are well; but when using "Find-Me" feature, MeetingPlace express dial to user, users via VG2 are can sent dtmf with MeetingPlace Express, but users via VG1 can not sent any dtmf digit to MeetingPlace Express. So users via VG1 can not enter the meeting.
Silver
Re: MeetingPlace Express strange problem!
Try Bug - CSCsc82613
Hi, this Bug dosen't have any relationship to my issues.
Have you tried adding 'dtmf-relay h245-alphanumeric' under your voip dial-peer on VG1?
Following is my VG1 config:
dial-peer voice 5 voip
destination-pattern 6100
session target ipv4:192.168.80.3
codec g711ulaw
no vad
We have the same problem with our H.323 Gateway.
Does anyone know a working configuration?
We had the same issue and made the following changes on the dial peer of the voice gateway:
incoming called-number .T
152
