Memory Upgrade for MCS-7845H-2.4-ECS2
For MCS-7845H-2.4-ECS2, there is only 1GB RAM. If I want to upgrade to 2GB RAM, is part no. MEM-7845H-2.4-1GB the correct part to be order?
If I order these 2 items together, will the extra 1GB RAM be installed before shipment or I need to install it myself?
Ryan
Re: Memory Upgrade for MCS-7845H-2.4-ECS2
Greetings Randy,
Yes, that is the correct part number for extra memory. Extra memory will arrive separate (possibly even in separate shipment) and you will need to install it.
/Wes
Has anyone purchased Compaq DL380 G2 specific memory, are there concerns about TAC support?
Crucial has 1GB RAM for the DL380 G2 for $295 http://www.crucial.com/store/listparts.asp?Mfr%2BProductline=HP%2BProLiant&mfr=HP&cat=RAM&model=ProLiant+DL380+G2&submit=Go#specs
268
