Message Waiting Lamp not working for voicemail
I have a user with a message waiting lamp for a 7970 that won't light up when he gets a voice mail. It does light when the phone rings. I checked the user options web page and it's still still set to "Default System Policy" which should cuase the lamp to come on for new voice mails.
Any ideas would be great
Regards, Chet
Re: Message Waiting Lamp not working for voicemail
Have you attempted to re-synchronise or refresh MWI status for the specific Subscriber in Unity?
Locate the specific subscriber in Unity and under Messages ensure the MWI extension is set to X if not already, and then click the refresh.
Allan.
That did the trick, thanks Allan !!
Hi Chester, glad I was able to resolve your problem.
Rgds
Allan.
Pls rate helpful posts.. Thanks
Hall of Fame Super Red
Nice troubleshooting Allan! +5 points from Calgary for sure my friend.
Cheers!
Rob
Cheers Rob much appreciated, all we strive for is the simple recognition..
Allan ;-)
That was the trick for me too.
Thanks for the help here!
Luke
190
