MGCP and H.323 on seperate FXO ports in same router?
I'm creating a testbed and need to configure H.323 and MGCP on different FXO ports within the same router. I've configured an H.323 gateway on one CCM and an MGCP gateway on another and can make calls VoIP->PSTN via both, but I get inconsistent results on which FXO port the call goes out. I've included my dial-peer config below ... is there something simple I'm overlooking? Perhaps something with the voip dial-peer?
dial-peer voice 2999 voip
description 10.41.5.30 is CCM_1
destination-pattern 2...
session target ipv4:10.41.5.30
dtmf-relay h245-signal
dial-peer voice 1 pots
description H.323 to CCM_1
destination-pattern 9T
no digit-strip
port 2/0/0
dial-peer voice 2 pots
description MGCP to CCM_2
service mgcpapp
no digit-strip
port 2/0/1
1 ACCEPTED SOLUTION
Re: MGCP and H.323 on seperate FXO ports in same router?
When using MGCP, CCM controls the dial plan, so the following commands are not necessary for the MGCP port and could be causing your inconsistencies.
no digit-strip
Please see the following quote from the link referenced below.
"Caution: Cisco CallManager controls all dial plan-related configuration elements. Do not configure these elements in the MGCP gateway for MGCP-managed endpoints (those with the application mgcpapp command in the dial peer statement). Do not configure any of these functions:
Under Dial Peers
destination-pattern
session target
Under Voice Ports
connection { plar | tie-line | trunk }"
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
Hope this helps. If so, please rate the post.
Brandon
no digit-strip
Under Dial Peers
destination-pattern
session target
Under Voice Ports
Brandon
If you are doing MGCP fallback, you need to configure the dialpeers with destination patterns and such.
See
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a008012ecc6.shtml
152
