MGCP Call Preservation
I have a question about MGCP Call Preservation;
I know it should work like this (2 callmanager cluster..);
phone (registered on cm1)
mgcp-gw (registered on cm2)
phone sets up call to PSTN
if cm2 fails, mgcp-gw will switchover to cm1 with Quit Clear flag,
so call will be preserved and RTP stream will continue....(learned this in IPTT)
But, what if phone and mgcp-gw are registered on cm2 (there is only 1 device-pool(cm2-cm1))
and cm2 fails, phone and mgcp-gw will switchover to cm1, and RTP gets lost.....(tested..)
Call is not preserved.
Is it possible to keep the call preserved?
Do I need to create 2 device-pools (1st for Phones, 2nd for gateways)?
Is there a design-guide/considerations for this?
regards,
Sascha
Re: MGCP Call Preservation
Im am curious why not register the phones and the VG200 to the same callmanager? That is what I do with my VG200 and my phones. I register everything to the Subscriber. Then If I have a failover everything goes to the Publisher.. Call calls are kept…
I have one Device Pool for my phones and gateways
That is just what I have (btw, it is a 2620 with E1 on MGCP..),
all registered on the sub, one device-pool.
But on a failover the rtp stream is gone after 3 sec!!
regards,
Sascha
How is the failover configured on your GW? gracefull/immidiate?Try with ccm-manager switchback graceful.
Alin
180
