MGCP - Call setup problem
I have a 3745 (12.2(15)T9) with a VWIC-1MFT and AIM module installed at a satellite office. There is a cluster of three CM's (3.3.3sr1) installed at the HQ, running MGCP.
From the satellite office, when i place a call over the PSTN, the call appears to connect when looking at the phone display, but there is no audio in either direction. Ringback is heard. These are dummy #'s, so no inbound call attempts have been made.
If i route the call through a different gateway that's in the HQ, the call is connected ok.
A debug for a failed call is shown below. As you can see, it doesn't get past the Alerting stage due to a 'Number Unobtainable' error.
Any suggestions would be appreciated.
142692: .Feb 27 17:26:51: ISDN Se0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00
02
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '8888'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '9123'
142693: .Feb 27 17:26:51: ISDN Se0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref =
0x8002
london-3745-01#
142694: .Feb 27 17:26:53: ISDN Se0/0:15 Q931: RX <- CALL_PROC pd = 8 callref =
0x8002
142695: .Feb 27 17:26:53: ISDN Se0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0
x8002
Display i = '*EC*00#*AA*NUMBER UNOBTAINABLE#'
**** CALL PLAYING DEAD AIR ****
**** HUNG UP CALL ****
142696: .Feb 27 17:27:24: ISDN Se0/0:15 Q931: TX -> DISCONNECT pd = 8 callref =
0x0002
Cause i = 0x8090 - Normal call clearing
142697: .Feb 27 17:27:24: ISDN Se0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x
8002
Cause i = 0x8290 - Normal call clearing
Display i = '*AA*CLEARED#'
142698: .Feb 27 17:27:24: ISDN Se0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref
= 0x0002
1 REPLY
Re: MGCP - Call setup problem
Hey Azam couple of points to note in the trace file. The called party number you are sending is 9123 to the PSTN make sure that you are stripping the 9 at the route pattern. I assume you are calling the speaking clock ?
Also the telco has not provisioned an ETSI Q.931 link for you. Call the telco and ask them to confirm that you have true ETSI Q.931.
C&W tend to supply this by default unless you specify ETSI. Would not mind betting this is a C&W link you have there :)
When you make the call connect after stripping the 9 you will see a messages on the phone that sent in the display IE. Like the one you see in the alerting. You need to get the telco to configure ETSI q.931 for you.
Neal
373
