MGCP E1 Framing issue
Anyone had an an issue where the Call Manager does not amend the Framing no-crc4 on a gateway. The gateway has to modified manually. Everything else works fine. Trouble is if the gateway reloads then the CCM overwrites the gateway with framing-crc4.
3725 running 12.3
Re: MGCP E1 Framing issue
After the correction, you can put "no ccm-manager config" and do a "write", then, everything will work and your config will remain the same.
THis will be solved in a future callmanager release, according to Cisco TAC
Dirk
Thanks Dirk.
Just found this CSCea47043
Paul
153
