MGCP Echo Cancellation Coverage
Using a 2821 with a VWIC-2MFT-T1 card controlled via MGCP - Call Manager 4.1.3 (sr1) On the Call Manager Gateway configuration the Echo Cancellation Coverage is "Default" What is or where do I find what the Default value is?
Thanks!
1 REPLY
Re: MGCP Echo Cancellation Coverage
The default is 64ms. You can do a "show voice port" on the gateway to see this information. Please see the following link for confirmation.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tvr/vrg_e1.htm#wp998290
Hope this helps. If so, please rate the post.
Brandon
474
