MGCP FXO Delay
I am running CM 3.3.2 SP C. I have an MGCP gateway with 6 FXO and a PRI. In my route list I am routing outbound calls out of the FXO ports then the PRI. When my FXO lines are down there is a long delay. Is there anyway around this?
Silver
Re: MGCP FXO Delay
Try changing the value for the CCM service parameter - MGCPTimeout. This value decides the number of seconds CCM will wait before it retries the request. The default value is 5 seconds. You may want to try out some lower values, say 3 or 2 and see if that helps.
Anup
Blue
Re: MGCP FXO Delay
You could try changing the timers on the FXO ports. I suspect what you are running into is the initial timeout which is 10 seconds by default.
voice-port 1/1/1
timeouts initial 10
Why don't you use the PRI as first choice?
Re: MGCP FXO Delay
Customer wants to go out of the analog first for some reason.
116
