Community Member
MGCP gateway not registering
I can NOT get my MGCP gateways to register with callmanager. I know the CM needs to be able to resolve the name, but it doesnt specify to which interface. Right now it resolves to loopback 0, but yet I see the router initiating a tcp session to CM from the serial interface. Is that possibly the issue?
*Dec 31 16:08:26.465: cmapp_host_fsm: Processing event GO_ACTIVE for host 0 (10.20.200.25) in state DOWN
*Dec 31 16:08:26.465: cmapp_start_host_tmr: Host 0 (10.20.200.25), tmr 0, duration 15000
*Dec 31 16:08:26.465: cmapp_open_new_link: Open link for [0]:10.20.200.25
*Dec 31 16:08:26.465: cmbh_open_tcp_link: Opening TCP link with Rem IP 10.20.200.25, Local IP 10.60.3.250, port 2428
*Dec 31 16:08:26.465: cmapp_open_new_link: Open initiated OK: Host 0 (10.20.200.25), session_id=4ABE0928
*Dec 31 16:08:26.465: cmapp_host_fsm: New state ACTIVE_OPENING for host 0 (10.20.200.25)
*Dec 31 16:08:26.473: cmbh_tcp_open_ind: TCP open failed for 10.20.200.25, calling callback.
*Dec 31 16:08:26.477: cmapp_host_fsm_process_event: Signal from unknown TCP session 4ABE0928
Re: MGCP gateway not registering
config this on the interface you want, look at the example
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Thats what I was looking for!
Oddly enough I decided to reload the router and it came up and my endpoints registered with out the command though. Bizzare.
Only thing I cant do now is call out on my FXS station, but I can call in to it.
637
