MGCP gateway problem
Folks,
I have 5 3845 gateways with 2 MFT1 cards them each. I am running into a strange problem. All gateways are running c3845-adventerprisek9-mz.124-6.T image.
I am using callmanager 4.1(3)SR3
All the Mgcp gateways(PRI) show up as unregistered under callmanager but i can make calls and receive calls through them. Also when i do a reset on them from the callmanager I loose a lot of my mgcp part of the config, example after a reset of mgcp gateway on the callmanager my controller will shut down and pri-group will be removed etc.
Why is this happening, i have been configuring mgcp gateway for 2 years now and never saw anything like this before, is it the code or the callmanager version maybe?
  • Other Collaboration Voice and Video Subjects
Re: MGCP gateway problem
Can you post your config? I assume that you have H.323 backup configured as well & this is how the calls are going thru.
Mike
hi Parwal,
it will be great if you can paste the MGCP config...
I am also having problem in cucm 8.6. call manger shows unknown however i am able to make calls. i dont have any other gateway.
any tips or helps on this would be appreciated.
thanks
SS
That might be just a RIS issue, try restarting the RIS service.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
760
