MGCP Gateway Won't Register
I'm trying to figure out why a 3825 won't register. This is the first time I've ever tried to configure this so it's probably something simple.
Here's the relevant router config:
ccm-manager redundant-host 10.29.23.1 10.0.23.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.23.1
ccm-manager config
mgcp
mgcp call-agent 10.0.23.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
In CCM administration, I've configured an MGCP gateway and I've verified (20 or 30 times!) that the MGCP domain is correct, taking into account that I've configured a domain using "ip domain name xyz".
I've tried debugging MGCP and I see that I'm getting a 500 response. That really seems to indicate a configuration problem but I can't figure out where.
What else should I look for?
Thanks!
John
Green
Re: MGCP Gateway Won't Register
Hi John,
Please paste the debug and check if you select the correct slot and card when you configured the GW.
The 10.0.23.1 should have TFTP service ON.
If you configured under the router ip domain name xyz
in CCM configured name of router lets say is MYROUTER.xyz
I am seeing a lot of stuff like the following (from debug mgcp):
*Jun 26 20:57:43.103: S0/SU0/DS1-1/23:NO-MATCH, 10.0.23.2:2427, 10.29.23.1:2427
*Jun 26 20:57:43.103: S0/SU1/DS1-*/*:NO-MATCH, 10.0.23.2:2427, 10.29.23.1:2427
*Jun 26 20:57:43.103: S0/SU1/DS1-0/*:NO-MATCH, 10.0.23.2:2427, 10.29.23.1:2427
I haven't selected the any cards yet because the cards we have are not available in the dropdown list on the gateway configuration page. We are using VWIC-2MFT-T1 modules but those are not available for selection. I assumed that once I entered the name of the gateway that CallManager would poll the gateway or something. If it doesn't, how am I supposed to tell CallManager about the VWICs?
Even stranger, I clicked on "Help" and I see that the VWICs should be one of the options listed, yet they are not there. That's bizarre.
Ah, I think I'm getting closer. I had to select "NM-4VWIC-MBRD" as the module in Slot 0. That opened up another section of the page where I can configure the subunits. At that point I can select the correct module.
I've reset the gateway in CallManager and restarted MGCP on the router but it still is not registering.
Whoo hoo! I got it to register. I finished configuring the gateway in CCM and reset it, and then I restarted MGCP on the router. It took a moment but it seems to have registered.
Green
Excellent!
567
