Silver
MGCP Gateways and Cisco Fax
We are considering adding a fax solution to our IPT infrastructure using Cisco Fax (Captaris RightFax). Ideally we would like the same voice gateways to terminate the fax calls (internal voice calls use QSIG and external calls use Q.931). Can this be achieved with MGCP-controlled Voice gateways? Can T.38 fax be configured with an MGCP gateway. I have seen examples where H.323 dial-peers are required to talk SIP to the Fax Server.
If not, is an alternative to use a back-to-back PRI connection between a voice gateway port and the Fax Server ISDN card, with appropriate route patterns in CallManager to route the fax calls to Fax Server, using Cisco Fax Relay?
Bronze
Re: MGCP Gateways and Cisco Fax
hi,
we have a RF installation with E1 isdn fax card on the server. It works very fine for us. we have configured fax-passthrough on the gateways.
With cm 4.2.3 there is t.38 support for mgcp gateway.
greetings
mehmet
Silver
Does your E1 fax card connect to an MGCP-controlled port on the gateway, and then you have appropriate route patterns configured to send fax calls to the RF server?
Bronze
all e1 controllers are mgcp controlled. one of them is rf e1 card.
PSTN---> e1 (38xx Gateway) ---> e1 (RF Server)
we have route patterns for the fax dns in direction of rf server.
greetings
mehmet
Can you provide an example of how the route patterns are configured for your Fax DNs in CallManager
Silver
Is it possible to use IP T.38 Fax Relay with MGCP gateways? The examples in the installation document I've seen on CCO use H.323 dial-peers to direct fax traffic towards the Fax Gateway using SIP. It would be preferable to use an IP mechanism rather than a back-to-back E1 connection between the voice gateway and the Brooktrout card.
Bronze
with cm 4.2.3 there is mgcp t.38 support implemented.
see release notes cm 4.2.3
http://www.cisco.com/application/pdf/en/us/guest/products/ps6729/c1178/ccmigration_09186a0080724724.pdf
regards
mehmet
Hey Guy,
Just curious how you got t38 to work with MGCP? I work with RF a couple times a month and I have not been able to get that to scream yet?
359
