MGCP help with 2600, CCM 3.1.2c and NM-HDV T-1 Enhanced module
I am trying to set up a gateway using MGCP, an
nm-hdv enhanced T-1 and CCM version 3.1.2c...I have set this up using fxo cards and the 2600 but I am not having the same luck with the enhanced NM..Any suggestions
Re: MGCP help with 2600, CCM 3.1.2c and NM-HDV T-1 Enhanced modu
Curious what IOS are you running on the 2600?
You can't register digital ports (e.g. T1 CAS or PRI) with the currently available versions of IOS because not all of the features are there to support this mode of operation yet. The first IOS release to support this is planned to be released very soon. Last I heard this was in the next week or two but that could possibly change. The version will be 12.2(2)XN. Note that CallManager 3.1 already has all the necessary functions to support this but until that version is available then you would need to use H.323.
96
