MGCP - Reorfer tone when using 4507R and WS-X4604-GWY
I have a 4507R with a AGM (WS-X4604-GWY) I have 4 VLANS on the switch
VLAN1 - Shutdown
VLAN2 - Users1
VLAN3 - Users2
VLAN4 - Voice
VLAN5 - Management VLAN
I have the SUPIV engine and the Gig6/1 is set for trunking and its native VLAN is set to 5
I have on the AGM the main
Gig0/0 - Set to an IP address on VLAN5
Gig0/0.2 - VLAN2
Gig0/0.3 - VLAN3
Gig0/0.4 - VLAN4
I have the dial-pper of
dial-peer voice 100 pots
application mgcpapp
incoming called-number .
direct-inward-dial
destination-pattern 9T
port 1/0:23
dial-peer voice 101 pots
application mgcpapp
direct-inward-dial
port 1/1:23
I can make calls out just fine, anywhere.
I can call interanlly anywhere.
When you try to call in you get one ring ang then, Sorry you have dialed an incorrect number if you feel you etc..
I am running MGCP I can get to the callmanager from the AGM.
Config
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname WO_LSB_4507_MPOP_1GW
no logging console
memory-size iomem 25
ip subnet-zero
ip host-routing
no ip domain lookup
ip audit notify log
ip audit po max-events 100
isdn switch-type primary-ni
voicecard mode toll-by-pass
voice call send-alert
voice rtp send-recv
ccm-manager redundant-host 10.110.0.3
ccm-manager mgcp
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
no ip address
duplex auto
speed auto
arp timeout 600
interface GigabitEthernet0/0
ip address 10.110.2.4 255.255.254.0
no negotiation auto
interface GigabitEthernet0/0.2
encapsulation dot1q 2
ip address 10.103.0.4 255.255.254.0
interface GigabitEthernet0/0.3
encapsulation dot1q 3
ip address 10.104.0.4 255.255.254.0
interface GigabitEthernet0/0.4
encapsulation dot1q 4
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
router eigrp 200
redistribute connected
redistribute static
network 10.0.0.0
no auto-summary
ip default-gateway 10.0.255.9
ip classless
no ip http server
call rsvp-sync
voice-port 1/0:23
voice-port 1/1:23
mgcp
mgcp call-agent 10.110.0.2 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
application mgcpapp
direct-inward-dial
port 1/0:23
application mgcpapp
direct-inward-dial
port 1/1:23
line con 0
line vty 0 4
login
voicecard sccp manager 10.110.0.2 port 2000
voicecard sccp local GigabitEthernet0/0
end
Any Ideas would greatly be appreciated.
Silver
Re: MGCP - Reorfer tone when using 4507R and WS-X4604-GWY
Sometimes direct-inward-dial causes problems. May be you can try the config without it.
Thanks for the reply, I got it working I took out the incoming called-number . out of the config and everything was in harmony -:)
94
