MGCP SRST Fallback question w/PRI network side emulation
Have a question regarding PRI setup w/MGCP then PRI when used in fallback mode (SRST).
MGCP gateway is configured to emulate network since PBX can only do user side.
Can we set the D channel in IOS config to emulate network there as well (for when in SRST mode) or will this over-ride the MGCP config? I haven't tried this yet and have looked for docs but haven't found any yet. My thinking is that MGCP would be in effect then when MGCP went down (failed) the normal router/gateway config commands would be in effect.
Is this right or not?
  • Other Collaboration Voice and Video Subjects
Silver
Re: MGCP SRST Fallback question w/PRI network side emulation
I do not think there should be any problem, and it should work as desired. As MGCP gtwy when with link to CCM up, and as h323 gtwy in SRST mode.
This depends on the gateway and IOS being used.
If you're using a CMM, all the current CMM SRST code has a bug in which the config will get over-written incorrectly by SRST.
Any 12.2.13T or high based SRST device should be fine. Simply put the "isdn protocol-emulate network" command on the Serial D channel interface and make sure your switch type is set correctly.
126
