03-19-2003 02:18 AM - edited 03-12-2019 11:07 PM
I have configured the MGCP gateway with IOS 12.2(8)T4. and CCM version 3.2.
In all incoming external call form mgcp gateway, i have unknown external number displayed on The IP Phones..
Are there any solution to display the destination number on the phones else display the source number ...
Thank you for you help !
03-19-2003 11:21 AM
What type of gateway? In gateway configuraiton do you have presentation bit allowed checked.
03-20-2003 01:00 AM
MGCP Gateway.. 3660 Router
I didn't find on Gateway configuration 'Presentation bit allowed'
Any comments ..
Thank you for your help !
03-20-2003 08:57 AM
Do you have a PRI, T1 CAS, FXO?
03-21-2003 06:27 AM
I have an FXO !!
regards
03-21-2003 07:00 PM
Do you have the command caller-id enable on your voice port?
03-22-2003 03:00 AM
Yes,
I have the command Caller-id enable on each voice port ...but nothing...
It's the same problem... at each external calls, i have unknown external calls...
any comments ..???
Are there any solution ?
03-22-2003 04:21 AM
Two things. Are you positive that the CO is sending you caller id? Turn on debug vpm signal. Do you see the caller id messages being sent from the CO?
03-22-2003 10:33 AM
I have used the debug vpm signal but nothing happen...
I have tried to make a external call to the ip phone and i have nothing message in the router ...
And i didn't see the caller ID message..
Any comments ?
