MGCP with FXO Problems
I have configured MGCP to access an FXO port used for our paging systems.
When I dial the access code, I get the Intercom Tone briefly then the audio goes away and I am showing connected. The voice port status even shows the interface as being up. When I hang up it shows idle.
Any Ideas?
We are running 12.2(15)T on the router. 2651
Re: MGCP with FXO Problems
After alot of debugging, I found the problem, but it doesn't make sense. I had to change the route pattern to remove the digits predot.
Example *5.
It was sending the *5 to the Intercom.
Can anyone enlighten me to the below the command?
mgcp dtmf-relay voip codec all mode out-of-band
I thought this command on the router removed the digits sent to an MGCP Gateway?
If I am wrong, please explain. Any explaination would help me.
Jason
Hi Jason - we are trying to
Hi Jason - we are trying to interface with a Dukane MCS350T.    Are you still using this configuration with MGCP and FXO?  We are having similar troubles and would be interested in a config if you have something functioning.
127
