Community Member
MGCP with one way voice
I have a 2611XM running MGCP with IOS c2600-is-mz.122-13.T8.bin with CM 3.3.3sr3. There is an AIM module with the E1 going into an Ericsson MD110 PABX running QSIG. Incoming and outgoing call is OK, but there is only one way voice. Only the IP phone could hear the conversation. Portion of the config is below. Anyone run into this problem?
network-clock-participate wic 0
network-clock-select 1 E1 0/0
voice-card 0
codec complexity medium ecan-extended
dspfarm
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.X
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server X.X.X.X
ccm-manager config
fax interface-type fax-mail
mta receive maximum-recipients 0
controller E1 0/0
pri-group timeslots 1-31 service mgcp
description QSIG PRI to MD110 Clock from PABX clocks Router
interface Serial0/0:15
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice modem
isdn T203 30000
isdn T310 60000
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
voice-port 0/0:15
echo-cancel coverage 24
cptone AU
description "30 Channel "QSIG" link to Ericsson MD110 PABX"
mgcp
mgcp call-agent 172.17.1.56 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
Silver
Re: MGCP with one way voice
You are having one-way voice for both incoming and outgoing calls. Check if your ip routing is ok, and the phones have the correct default gateway to reach the 2600 router.
Silver
Community Member
Hi Vinh, could you tell me the cable pin-outs you used for the connection between your router and Ericsson MD110 PABX as i have to set up the same.
Thanks for your help.
Community Member
I'm using 2-wire - Type 5 integration.
Community Member
Hi AZAM
Unable to help you with this because it was setup originally by someone else.
155
