mgcpapp and MGCPAPP
I remember somewhere in the CCO it states that use either mgcpapp or MGCPAPP depending on the routers platform, something like that. Is this still true?
Re: mgcpapp and MGCPAPP
Take a look at the link below which states:
"Note: The application MGCPAPP command is case-sensitive in some Cisco IOS software releases. Always issue this command in uppercase unless you know that your software release is not case-sensitive. Look at the output of the show running-config command in order to check whether your software release is case-sensitive. Cisco IOS Software Release 12.1(5)T is not case-sensitive."
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
Hope this helps. If so, please rate the post.
Brandon
Also,
now that the application command is deprecated, you need to use the service command. Inside the dial-peer mode if use a "service ?" you will see the list of applications available. You will see that MGCPAPP is listed in all caps. In newer IOSes' (12.3,12.4) I have seen that it does not matter how you enter it (mgcpapp or MGCPAPP)..it shows up in running config in lower case "mgcpapp" and both works.
Sankar
PS: Please remember to rate all posts!
148
