Migrate from ios 12.2(2)XB15 to 12.3 cisco AS5350 problem.
Hi. After migration on ios 12.3(10e), IVR script send to radius attribute "l2tp-cm-retransmit-retries" instead of "h323-ivr-out". IVR TCL v1.1
This part of script:
set av-send(h323-ivr-out,0) "bm-paycard:$paycardID"
set ev [authorize $account $pin "" "" av-send info]
part of debug:
Nov 24 10:24:55.411 MSK: AAA/AUTHOR (0x3): Pick method list 'h323'
Nov 24 10:24:55.419 MSK: voip_start_authorization_ext: has av 1
Nov 24 10:24:55.419 MSK: voip_start_authorization_ext: adding attr 184 name=l2tp-cm-retransmit-retries val=bm-ani-check:XXXXXXXXXX
1 REPLY
Bronze
Re: Migrate from ios 12.2(2)XB15 to 12.3 cisco AS5350 problem.
It is either the TCL script is not processing the ACM GTD correctly when looking for ORI, or theIOS is not passing the correct thing to the TCL script. I suspect that the root cause of this issue is the dual PCI that we get in the ALERT message and the ability of the TCL script to handle two PCI messages on the same signal.
124
