Bronze
Minimum Command for MGCP T1 PRI
Hi all,
CCM 4.13 (no special engineer or patch install, Publisher and Subscriber.
There are minmum command for MGCP, after register CCM, CCM will upload the rest of command to MGCP Voice Gateway.
For some reason, I couldnt make MGCP download file from CCM, I have to manually type all the command and it works.
However, I want to know why the MGCP could not download file from CCM???
Here is my configure:
network-clock-participate wic 0
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-3,24 service mgcp
interface FastEthernet0/0.11
description HQ-Data
encapsulation dot1Q 11
ip address 192.168.200.1 255.255.255.0
interface FastEthernet0/0.111
description HQ-Voice
encapsulation dot1Q 111
ip address 10.1.200.1 255.255.255.0
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:23
ccm-manager redundant-host 10.1.200.21
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.200.20 10.1.200.21
mgcp
mgcp call-agent 10.1.200.20 service-type mgcp version 0.1
mgcp bind control source-interface FastEthernet0/0.111
mgcp bind media source-interface FastEthernet0/0.111
mgcp profile default
Anyone can tell what I am missing??
Ken
P.S. here is debug mgcp events:
*Aug 15 14:26:28.247: * mgcp_msg_ack: Setting the restart method to NONE
*Aug 15 14:26:28.247: mgcpapp_process_socket
HQ#
*Aug 15 14:26:43.243: MGCP sys msg: (15)
*Aug 15 14:26:43.243: xlate sys msg: (15, 4524AF5C)
*Aug 15 14:26:43.243: sys msg values: (INVALID MGCP EVENT, 0, , 0, CALL_IDLE)
*Aug 15 14:26:43.243: process mgcp_handle_cmapp_event
*Aug 15 14:26:43.243: mgcp_cmapp_send_keepalive send NTFY KeepAlive
*Aug 15 14:26:43.243: send_mgcp_empty_notify_msg: endpt *, complete_endpt *@HQ
*Aug 15 14:26:43.243: * mgcp_get_ca_addr_port:
*Aug 15 14:26:43.243: * mgcp_get_ca_addr_port: Used endpoint NE 10.1.200.20:2427
*Aug 15 14:26:43.243: mgcp_get_preffered_ip
*Aug 15 14:26:43.243: * mgcp_get_ca_addr_port: NE addr 10.1.200.20:2427
*Aug 15 14:26:43.243: * mgcp_enq_retx_msg: trans_id 234089142,ntfy_ent 10.1.200.20:2427
*Aug 15 14:26:43.243: * mgcp_root_get_profile:
*Aug 15 14:26:43.243: mgcp_add_trans_id_rec: Add trans id (234089142, 45B26378) record
*Aug 15 14:26:43.243: mgcp_stw_timer_start timer type 0, duration 500
*Aug 15 14:26:43.243: send_mgcp_empty_notify_msg NTFY Packet sent successf
HQ#ully - *
*Aug 15 14:26:43.247: MGC stat - 10.1.200.20, total=43, succ=22, failed=20
*Aug 15 14:26:43.247: mgcpapp_process_mgcp_msg : <NEW MGCP MSG From CA>
*Aug 15 14:26:43.247: * mgcp_msg_ack
*Aug 15 14:26:43.247: MGC stat - 10.1.200.20, total=43, succ=23, failed=20
*Aug 15 14:26:43.247: * mgcp_msg_ack: Removing msg : NTFY 234089142 *@HQ MGCP 0.1
X: 0
O:
*Aug 15 14:26:43.247: * mgcp_msg_ack: Setting the restart method to NONE
*Aug 15 14:26:43.247: mgcpapp_process_socket
1 REPLY
Re: Minimum Command for MGCP T1 PRI
Also key in,
ccm-manager config
Sankar
PS: please remember to rate posts
340
