Missed calls/received calls
I am getting all 10 digits in my missed calls or received calls. I would like to make call from there by hitting dial in missed calls but it doesnt go through since it needs 9 to dial out is there any way to add 9 or 91 to call directly.
Re: Missed calls/received calls
The only way I know of other than making some router pattterns is to hit edit dial then dial a 9 then dial
Blue
Create a translation rule to add 91 to all incoming calls. Only disadvantage is that incoming calls will show up as 91XXX-XXX-XXXX.
How do you address the issue of missed local vs. missed long distance calls? It seems that if you add a 91 to all incoming calls then you can do a dial on calls as long as they are long distance but what if the call is local? Is there a way to add a 9 to certain area codes that come in and a 91 to anything else?
what will be the translation pattern for incoming calls.
171
