Missed Calls Redial
This has probably been asked before but I have an issue with missed calls redial. Basically what is happening is that the telco is not sending the full number, they are dropping the leading zero of the calling number and hterefore when you try to dial a missed call it fails. This also fails because the user has to dial an access code to gain an outside. does anyone know how to get round the missing digits. I thought of using translation patterns but this could interfere with other internal numbes dialled. Is there a system parameter somewhere ??
1 REPLY
Re: Missed Calls Redial
I have noticed the same problem and could not find a workaround. I have opened a case requesting a feature upgrade on Call manager.
I also tried this on an IOS router but the translation only applies in outgoing calls or voip-incoming.
PS Bug ID was CSCdr73116 which has been assigned to an engineer
154
