MLA issue
When I go to user group page I get the following error:
An error occurred while the page was loading
Error Number: -1 Description: Operations error
Green
Re: MLA issue
Version of CCM?
AD or DCD integration?
If you perform a query for Users under Global Directory works fine?
Gonz
Re: MLA issue
CM = 4.1 sr2
AD integration
Yes I can query for Users under Global Directory
Re: MLA issue
Hi there,
Here is the fix
You need to make some changes in the SQL Database as the search is was wrong you cant assign users to groups.
In SQL manager CCM0300 database in tables Select the MLAParameter
(return allrows)
change some paths on the following NAMEs to your companies as per AD integration
"MLAUserBase" ou=Logins,dc=ap,dc=yourcompany,dc=com
and "MLADirBase"
ou=MultiLevelAdmin,ou=Cisco,dc=ap,dc=yourcompany,dc=com
Go into CCMAdmin and MLA parametres and check this was updated and you can assign a user to superuser group.
logon with the new user.
regards
Allan
Re: MLA issue
excellent thats works great
109
