MLA Issue
I have a problem enabling MLA. When I try to enable MLA, set Enable MultiLevelAdmin = True and Update, the window prompt a message saying: "User Group Base contains one or more invalid characters. Valid characters for User Group Base are letters, numbers, space, dots, commas and the following character(s) = "
I am using CCM 4.0
I don't think the enter wrongly on the User Group Base..
Can anyone suggest how I workaround this.
Many Thanks
Justin
1 REPLY
Green
Re: MLA Issue
Hi Justin,
Are you using DC or AD?
Found CSCef82196
Condition:
- Install CCM 4.1(1.41)
- Run Plug-in for Active Directory
- Restart IIS Admin service
- Start CCMAdmin browser
- Go to User->Access Rights->Configure MLA Parameters page
- Make sure no error is displayed
- Go to User->Access Rights->User Group Page
Symptom:
Following error is seen :
An error occurred while the page was loading
mla.asp::isMLAAdminEnterpriseUser() Exception Err=-1
description=Operations error Cannot create
UMMLAProviderX!
Workaround:
Update MLAParameter table in the CM Database
for Name='MLAUserBase' with the correct value (for AD Userbase)
for Value
Example :
(name='MLAUserbase' and Value='cn=Users, dc=prijo,dc=cis,dc=com')
I also found this DDTS:
CSCef66945
Error on user group page after installation of Cisco Customer Direct
Symptom:
Error on user group page after installation of Cisco Customer Directory
Conditions:
Steps to reproduce
1.Enable MLA.
2.Install the Cisco Customer Directory Configuration Plugin.
3.Go to the user configuaration page.
4.The following error is seen.
Error Number: -1 Description: Operations error
Workaround:
none
But the one I mentioned at the beginning is the one you should use.
Let me know if the User Group contain any dashes (-)
CSCeh02679
Externally found moderate defect: Resolved (R)
Dash/Underscore is an invalid char in User Group Base but not for DNS/AD
The file that does the Group Base validation is
C:\CiscoWebs\Admin\includes\standard.js ; Line 131 defines the valid characters for it.
var maskForMLAUserGrpBase = maskAlphaNumeric + charComma + charEqual + charDot +
charSpace;
In order to support a "-":
var maskForMLAUserGrpBase = maskAlphaNumeric + charComma + charEqual + charDot + charSpace
+ charDash
//G
126
