Mobility Manager on MCS-7825-H1-IPC1
I sold a customer a MCS-7825-H1-IPC1 for Mobility Manager, is there any way to get Seadragon/Mobility Manager to install or do I need to RMA the 7825 for a MCS-7815-I1-IPC3
I thought the problem was Linux drivers for the HP Embedded SATA RAID Controller Driver for Red Hat Enterprise Linux 4 (x86) don’t exist, but I see them here;
http://h10018.www1.hp.com/wwsolutions/linux/Linux_Storage.pdf
http://www.cisco.com/en/US/products/ps6567/products_data_sheet0900aecd8031a327.html
1 REPLY
Re: Mobility Manager on MCS-7825-H1-IPC1
Jason,
This is a fairly recent product and I dont think any other hardware other than 7815 is currently supported. If you look at the last link you posted, it even says 7815 (initially).
I am sure there might be a way to bypass the hardware check, but i would recommend to go with replacing the server with a 7815.
Sankar.
PS: please remember to rate posts!
125
