Modemproblems with VG248 and CCM 3.3.2
hempend
Szenario
CCM 3.3.2 with 36XX PSTN Gateway H323
VG248 for analog Fax and Modems
I want to use VG248 for analog Dial in Modems.
But it ´s confused. The connections are dirty or corrupted. If i get a connection the speeds are low.
I changes the VG248 Konfig to IOS mode but it´s no solution. Is there somebody who has a functional configuration for me or a idea for a functional configuration parameter?
s-pinto
I´m using VG248 with modem and everything works fine.
I´m using IOS mode too.
I presume you are using modem passtrough on the H323 gateway.
Regars,
Sergio Pinto
madhatter
Hey there,
I have done about 5 VG248 install's and there have been much talk through Cisco about the analog services over IP. The VG248 can only do about 30kbps; some faxes will have problems if you try to send at super g3 speeds.
take a look;
http://www.cisco.com/en/US/customer/products/hw/gatecont/ps2250/prod_release_note09186a008007fd6c.html
DDTS:CSCdv37478 shows the connection speed limitation.
These guys can be a pain and require tweaking for specific fax machines. Some modem apps won't work. Analog lines are your saviour if you need a quick solution.
Cheers
Andrew
