MOH, callerID, and other problems
Hi guys,
Could you help to solve some of these problems?
I have an installation with 1 callManager, and a PRI QSIG connection to a Phillips PBX which makes the link to PSTN.
- I don't hear the Music On Hold when I call from the PSTN.
- When I call to the PSTN from an IP Phone, I get only the general caller ID but not the extension.
Thanks in advance
Jean-Philippe
Re: MOH, callerID, and other problems
Jean-Philippe,
1. With regards to the MOH problem, do you hear music when an ip phone is put on hold by another ip phone?
2. Some things to check are:
-- Make sure the calling party number is withing the DID range assigned to you.
-- Make sure you are classifying the calls the way the CO requires. Ask them about the plan and type classification that they require.
-- In the gateway configuration in CallManager, make sure presentation bit is allowed.
Michael.
Hi Michael
Thanks for your answer.
I think for the calling number, it's OK, I asked my provider.
For MOH problem, when I use the codec G711, I only have MOH on internal phones, but when I use G729, I can go through the 3640 Gateway. Is it possible to have G711, because the quality of the streams is quite poor with G729.
Jean-Philippe
102
