MOH for IP Communicator
Hello!
I have some stupid question :)
IP Communicator support MOH when call place between to IP Communicator?
I set up some IP Phone 7940 and 2 IP Comminicator with CME 7.0.1. All phones locate in one switch and subnet.
MOH correctly work with IP Phone 7940 and external calls.
But when place call between IP Communicator MOH not work, I hear some beep.
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 mtp001f6c95dff0
em keep-history
max-ephones 25
max-dn 20
ip source-address 192.168.2.100 port 2000
timeouts ringing 40
system message F
cnf-file location flash:
cnf-file perphone
user-locale RU
user-locale 1 U1 load CME-locale-ru_RU-Russian-7.0.1.1.tar
network-locale RU
network-locale 1 RU
load 7960-7940 P00308000400
time-zone 32
time-format 24
date-format dd-mm-yy
voicemail 5000
max-conferences 10 gain -6
call-forward pattern .T
moh moh_tch.wav
multicast moh 239.0.0.1 port 16834 route 192.168.2.100
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
directory entry 1 1000 name mnb
create cnf-files version-stamp 7960 Jan 27 2009 14:22:46
Re: MOH for IP Communicator
Hi!
Yes, IP communicator supports MOH and if they are on the same LAN MOH should work.
MOH for internal calls was introduced in CME 4.0 with the multicast-moh command, which you have.
*** Cisco Unified Communications Manager Express System Administrator Guide ***
--> Configuring Music on Hold
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010356
Check if the IPCs have the mtp or the paging-dn command as this is one restriction of MOH.
". The multicast MOH feature checks to see if MTP is enabled for a phone and if it is, MOH is not sent to that phone"
Check this link:
--> Restrictions for Music on Hold
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1012460
Hope this helps!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Thank for your reply! I have read this documents but can`t resolve my problem.
MOH for IP Pone (7940) work correctly.
IP Communicator 7 install on Windows Vista and WinXP computers.
Call from IPC to 7960:
Results of debug eph moh:
035970: Jan 30 10:01:52.024 MSK: MoH route If FastEthernet0/0 ETHERNET 192.168.2.100 via ARP
035971: Jan 30 10:01:56.316 MSK: ephone_hold_resume ignored for s2s set on dn=1 chan=1 hold=1 callID=908
035972: Jan 30 10:01:57.168 MSK: MoH route If FastEthernet0/0 ETHERNET 192.168.2.100 via ARP
035973: Jan 30 10:02:01.740 MSK: No MOH entry for DN 1
Dear
I have the same problem.
CME 4.2 ,ip comm 7.2.
Debug..
sccp 7960 > ip comm (sccp softphone)
7960 press hold
moh isn't work
*Mar 20 17:45:41.149: ephone_hold_resume ignored for s2s set on dn=1 chan=1 hold=1 callID=3441
*Mar 20 17:45:58.737: No MOH entry for DN 1
*Mar 20 17:45:58.737: ephone_hold_resume ignored for s2s set on dn=1 chan=1 hold=0 callID=3441
ip comm press hold
moh is work
*Mar 20 17:46:17.673: ephone_hold_resume: update huntgp hold time: dn=3 chan=1 hold=1 callID=3442
*Mar 20 17:46:17.673: ephone_hold_resume ignored for s2s set on dn=3 chan=1 hold=1 callID=3442
*Mar 20 17:46:17.673: McastMoh is Available
*Mar 20 17:46:28.449: No MOH entry for DN 3
*Mar 20 17:46:28.449: ephone_hold_resume: update huntgp hold time: dn=3 chan=1 hold=0 callID=3442
*Mar 20 17:46:28.449: ephone_hold_resume ignored for s2s set on dn=3 chan=1 hold=0 callID=3442
1028
