Moh not in use - gives errors anyway
We are not using Moh on our CallManager 3.2, however, everytime someone is put on hold, the Application Event Log records this error: UNKNOWN_ALARM:MohNoMoreResourcesAvailable [source: Cisco CallManager, Event ID: 3]
Everything works as expected but our logs are jammed full! Any ideas on how to get rid of this error?
1 ACCEPTED SOLUTION
Silver
Re: Moh not in use - gives errors anyway
If you are running CallManager 3.3(2) the following bug might exlain this behavior.
CSCeb54528 Bug Details
Headline MohNoMoreResourcesAvailable errors when MoH is not configured
First Found-in Version 3.3(2)
First Fixed-in Version 3.3(2)FP02, 3.3(3.8), 3.3(3)ES04, 3.3(2)ES39, 3.3(3)SR02, 3.3(2)FP1.6, 3.3(2)ES49
Symptom:
The following error is logged to the Application Event Log
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 7/2/2003
Time: 2:03:36 AM
User: N/A
Computer: ServerName
Description:
Error: UNKNOWN_ALARM:MohNoMoreResourcesAvailable -
App ID: Cisco CallManager
Cluster ID: CMName-Cluster
Node ID: x.x.x.x
Explanation:
Recommended Action: .
Condition:
This has been observed in CallManager version 3.3(2) Support Patch C. It has
seen in the latest Engineering Special at the time of this submission,
3.3(2)ES34. This BUG is related to having the IP Voice Media Streaming
Application
deactivated.
Workaround:
The only workaround is to enable MoH.
Gold
Turning off the MOH services without deconfiguring the system for MOH will result in this exact error; basically that CallManager searched for a MOH server and wasn't able to find one, and fell back to tone-on-hold.
Look on the phones themselves and on their device pools to see if they have User or Network MOH sources defined. If they do, redefine them as "". For good measure, make sure that the Media Resource Group List and its underlying Media Resource Groups contain no MOH servers, otherwise I think CallManager might fall back to the clusterwide-default MOH source, which is usually #1.
Everything you have suggested is the way it is set; the default Device Pool is in use and has "none" as it's "User Hold Audio Source" and "Network Hold Audio Source". In fact, there are no other options. I've looked at a couple phones specifically and they are set the same way, then retested and the errors came back.
Same with MRG and MRGL's - Moh is not included.
Any other ideas? Thanks for your time.
Silver
Symptom:
Event Type: Error
Event ID: 3
Date: 7/2/2003
Time: 2:03:36 AM
User: N/A
Description:
Node ID: x.x.x.x
Explanation:
Condition:
Application
deactivated.
Workaround:
Thank you... that is it. We are in fact running 3.3(2) and that describes it exactly!
Just to add to this, this bug is fixed in CM 3.3(3) SR2.
140
