Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MOH will not stop
I have CM 3.1.3a and have tried to turn off MOH on certain lines. It seems to work on internal calls but not on external calls. I made sure that the gateway has it turned off also. So what am I missing?
Re: MOH will not stop
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Bronze
You might want to check the Device Pool Configuration (under System) and make sure the MOH preferences are not checked.
Also, if you want to completely disable MOH, remove the MRGL from all device pools AND create a new MRGL for the MOH servers. That will make sure that any configurations done explicitly on the phones will have no way of reaching the MOH server. And restart all devices.
If you want to disable MOH all together system wide. Just set the run flag to false on the MOH servers. In 3.1 you have to go to service -> moh. Then in the upper right click configure MOH servers. Then click on each 1 to set the run flag to false. Then update. In 3.2 service -> media resource -> moh servers.
Hope this helps,
-Mckee
116
