Monitor multiple phone for incoming call
I want to monitor multiple phone incoming call (retrieve callerID, ...)
I do that with Tapi, but when you configure TSP, it's only for one phone
I can install TSP several times, but ... for 40 phones ...
Are there other solutions ?
I use CCME
Re: Monitor multiple phone for incoming call
Yes, you can use packet capture to sniff skinny. It works really well, and transparently across CallManager and CallManager Express. You'll need to perform packet decode which is a bit of work, and connect your server to the appropriate SPAN port, of course.
You can also assign multiple phones (lines) to that specific user in the callmanager.
117
