Monitoring DCD/LDAP Connections
Anyone know of a way to use Real-Time Monitor to check DCD/LDAP connections (TCP Port 8404) to Callmanager 4.0(2)SR1a? I browsed through the parameters, though can't find the one I need.
FYI, this is to help research a recent occurrence of this:
Event Type: Warning
Event Source: DCDirectory
Event Category: Configuration
Event ID: 9415
Date: 3/10/2006
Time: 11:28:50 AM
User: N/A
Computer: ABCCM1
Description:
(BASE IL NEW CONNECT(46) Proc 88, Sev 14)
No free connection control blocks - connection refused. This
indicates that the maximum number of simultaneous TCP/IP
connections has been reached, and further connection
attempts will fail until one of the existing connections
has been closed.
Socket ID 407F0006
Component LDAP
Number of CBs configured 504
We want to find out which app is taking the connections. No need to forward me the bug reports on this error, I read them all.
Thanks in advance.
Re: Monitoring DCD/LDAP Connections
There is a DirectoryConnectionFailed alert in RTMT. Go to Alert -> Alert Central. It doesn't give details about the failure, but it will tell you when it fails.
Hope this helps. If so, please rate the post.
Brandon
Great - thanks!
You're welcome. If you found the information helpful, would you mind to rate the post? Have a great day!
Brandon
113
