Community Member
Monitoring Unity
Hi all:<br><br>Is there any monitoring solution or agents that can actually monitor Unity Services and ports so if the system goes down I know before the users know?<br><br>Thanks,<br><br><br>Erik L. Vesneski<br>Internal Network Manager<br>www.epicentric.com
1 REPLY
Community Member
Re: Monitoring Unity
There is none in Unity 2.4.6.
With Unity 3.0 you have the Event Notification Utility which can do some of this. It does not know if the port it down, but it down know if the Unity services shut down.
Anil Verma
Cisco Systems
anilve@cisco.com
93
