More than 9 option in Caller Input
Is there a way to define more than 9 options on a Callhandler/Caller Input. For example for 10 or 11....<br>The customer does not want to break the menu...I need * and # and 0. So it needs to be combination no 10, 11<br><br>Sean Poure<br>NEC-Voice Engineering<br>Sr. Systems Engineer<br>714 4846275<br>
Sean Poure
  • Other Collaboration Voice and Video Subjects
1 REPLY
Anonymous
N/A
Re: More than 9 option in Caller Input
There is no way to do “double key” rules with Unity. You’ll have to break their menus into two or more levels if 9 options off a greeting is not sufficient to handle their application.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
114
