MRP and H.323 gateway problem (ICS-7750)
>>Additionaly, where can we set the H.323 alias of the gateway ? It register >>with its IP address.
>mrp-selxml(config)#int fa 0/0
>mrp-selxml(config-if)#h323-gateway voip h323-id xxxxxxx
Can I configure that via the Windows interface ?
I succeeded to establish a call between my H.323 endpoints and the PSTN via the Cisco h.323 gateway. My problem was that the gateway register to the gatekeeper with the first ip address (in my case 192.168.202.1) and the address of the MRP is 192.168.202.5. Without the gatekeeper the call succeed. But when it register to the gatekeeper with 202.1, the gk route the call to this address and CCM reject the call.
Is there a way to register the MRP to the gatekeeper instead of the CCM ?
1 REPLY
Re: MRP and H.323 gateway problem (ICS-7750)
The MRP when used as an H.323 gateway can be registered to a gatekeeper.
To control the address that an H.323 gateway uses to register with a gatekeeper use the following command under the appropriate interface:
h323-gateway voip bind srcaddr
This command when used under any interface specifies that the gateway should use the interface ip-address when involved with H.323 calls/call flows.
For example:
interface Loopback0
ip address 10.1.1.1 255.255.255.255
h323-gateway voip bind srcaddr 10.1.1.1
Check out the following for more information on this command:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t2/dt323bnd.htm
Jordy
96
