MSXML HTTPS/SSL problems...is there a solution?
Hi All,
I have finally managed to get push2phone.asp working after studying some of the replies here - but only to a single hardcoded IP address. I am still stuck with the shortcomings of MSXML when getdeviceip.asp tries to attach to the Callmanager over https/ssl - 'A security problem occured'.
I have looked at every reply on this forum but there does not seem to be an answer to this problem. Can anybody say for sure whether there is a workaround and if so what is it?
1 REPLY
Re: MSXML HTTPS/SSL problems...is there a solution?
I'am having the same problem since the 3.X sdk release using CM 4.1, now I found that the SDK 4.1 was release and I was expecting that this will solve this issue but I have no success. Any update to this??
269
作成コンテンツを作成するには してください
