MTP Configuration for SIP DTMF relay using callmanager 5.0
My set up is like i have a sip trunk from ccm 5.0 to a nextone session border controller.
I have configured 2811 has an MTP device for outband to inband dtmf conversion..
When ever i place a call to any ivr device n press any digits as requested...it doesnt work..
Configuration for cisco 2811 router are as follows.
Current configuration : 2180 bytes
version 12.4
hostname xxxx
boot-start-marker
boot system flash c2800nm-ipvoice-mz.124-5.13.T4.
boot-end-marker
card type t1 0 0
! card type command needed for slot/vwic-slot 1/1
no aaa new-model
resource policy
no network-clock-participate slot 1
network-clock-participate wic 0
ip cef
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
no dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface FastEthernet0/0
ip address 172.24.6.75 255.255.252.0
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ntt
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 172.24.6.1
ip http server
control-plane
voice-port 0/0/0:23
ccm-manager redundant-host 172.24.6.72
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.24.6.72
ccm-manager config
mgcp
mgcp call-agent 172.24.6.73 2427 service-type mgc
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 172.24.6.73 identifier 2 version 5.0.1
sccp ccm 172.24.6.72 identifier 1 version 5.0.1
sccp ip precedence 3
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2811 register 2811_MTP
dspfarm profile 2811 mtp
codec g711ulaw
maximum sessions hardware 8
associate application SCCP
line con 0
password xxx
line aux 0
line vty 0 4
password xxx
login
scheduler allocate 20000 1000
end
MTP is configured and registered correctly with ccm5.0 but somehow it is not able to do the dtmf conversion..
Attached is the ccm trace also.
guys plz help me to set this mtp for dtmf conversion
Thanks in advance ...
Shirish
1 REPLY
Re: MTP Configuration for SIP DTMF relay using callmanager 5.0
ccm5 is not publically available yet afaik, where did you get it?
437
