Multi Language with ICD
Ok, the manuals leave much to be desired here. In CRA v3, in the application editor you have the ability to "Set prompt Language" by using the "Set Contact Info" component. Although you set this to a variable. Is this variable supposed to be the Directory name of each language (ie: "en_US" or "fr_CA"). If so, are you then just able to execute a play prompt for a common filename in which case it'll play that .wav from the selected language directory?
Or am I missing something real stupid here.
John.
Re: Multi Language with ICD
I have just done it in the CRA 3.0.2 but not in ICD.
Intially when u install the CRA you have to chose the language as bothe english and spanish and creat a Varible give a name what you want and at the boton mention the language you slected there for
ex: if it is US Spansih put there es-US and then change thecontact info with this varible.
Then you shoudl be able to use both the languages.
Raj.
What if you didn't install another language during the initial installation? Do you know how you could install additional languages afterwards?
Also, when you do have additional languages, is it just a matter of using the "set contact info" step and setting the Language parameter to the language variable?
Thx!
118
