You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
multicast routing for MOH
I want to use multicast routing for Music on Hold. I am running h323 on my voice gateways.
I have one centralized call manager and several remote sites with IP Phones.
Does anyone have any good router configs for setting up multicast routing??
  • Other Collaboration Voice and Video Subjects
Re: multicast routing for MOH
The main thing you need to do on each router is enable ip multicast-routing and in addition, on each router interface through which the MoH packets may travel, you should enable one of:
ip pim sparse-mode
ip pim sparse-dense-mode
ip pim dense-mode
A good document for reading about this is:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcpt3/1cfmulti.htm
Additionally, if you have any follow-up questions that this does not answer or if you have any trouble setting it up, please contact the Cisco TAC and open a case regarding IP Multicast routing.
I have validated Multicast MOH with an MGCP gateway (I think it does not work with H.323). Once you have enabled multicast in CCM config (audio source, moh server and MRG), you just have to configure 'ccm-manager music-on-hold' in the gateway so that it receives the multicast address when a PSTN user is put on hold.
Here is an excerpt from the gateway config (mostly done by CCM) :
ccm-manager mgcp
ccm-manager config server 192.168.10.10
ccm-manager config
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial1/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn sending-complete
no cdp enable
voice-port 1/0:15
cptone FR
mgcp
mgcp call-agent P-MCS-P 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 9991015 pots
application mgcpapp
port 1/0:15
gateway
185
