Blue
multidirectory.asp
I am use the multidirectory.asp file that comes with the IPPS SDK. I have it installed on a seperate server as its not supported to install the SDK on CallManager.
The problem I have is that I have a cluster in Europe so the values for the All Directory Search and the searches for the other clusters do not follow the localization rules of the phone. These values all show up in English.
This is obviously because I have these values defined in the multidiretory.asp file and not in the localization file like I would do if I was using CallManager to serve up this file.
Anyway, has anyone run into this. Any ideas on what I can do?
TIA
1 REPLY
Re: multidirectory.asp
It?s happends because library Directory doesn`t work. You must write the text like a string including softkey buttons.
Best Regards
211
