Multidirectory work with CCME
Folks,
I am using the multidirectory tool kit. It works perfectly fine with the 2 call manager clusters i have. Basically it connects to the DC directory of both the callmanager for information and automatically appends a digit when calling out.
My problem is that now i have a CCME that i have to hook up to the cluster. Can i use the multidirectory tool to get direcorty information from the CCME?
1 REPLY
Silver
Re: Multidirectory work with CCME
Cisco PTC - VS supports synchronization through the Network Builder process which is available from the Managed CCME, PSTN H.323, and PSTN MGCP tabs in the Cisco PTC - VS Main window.
This URL should help you:
http://www.cisco.com/global/MX/SemTecRouting/05ccme_cue_broch.pdf
95
