MultiLevel Admin and Active Directory
Has anybody integrated these two yet?
George.
My Current Error:
User Group Configuration
An error occurred while the page was loading
Couldn't create Multi Level Admin node. Check "Directory Base" in "MLA Enterprise Parameter Configuration" page
MLA Configs
All MLA Enterprise Parameters
Parameter Name Parameter Value
Directory Base - ou=MultiLevelAdmin,ou=Admins,o=cisco.com
Debug Level - None
Effective Access Privileges for overlapping user groups - Maximum
Effective Access Privileges for overlapping functional groups - Maximum
  • Other Collaboration Voice and Video Subjects
Re: MultiLevel Admin and Active Directory
I have in a test lab. I installed CM 3.2, then The AD Plugin, then Multi Level Admin. Works fine as far as I can tell.
My only complaint is that once you log into CCMAdmin, if you access BAT it prompts you for authinication.. They should link BAT into the system just like CAR
Can you access the user and functional groups? If so, I must have installed MLA before AD and thus couldn't get them to talk.
I will reinstall MLA and see if it makes any difference. Will keep you posted.
George.
114
