Multiple incoming dial-peer matched
Dear,
Could someone, tell me why after matching an incoming-peer on "answer-address" system matches for same call another  incoming dial-peer based a "destination-pattern" ... shouldn't the system start looking for outbound dial-peer once first incoming diapeer matched?
046565: Feb  3 17:56:57: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=360
046566: Feb  3 17:56:57: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1660, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
046567: Feb  3 17:56:57: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
046568: Feb  3 17:56:57: //-1/4C84D3B79834/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1660, Called Number=+32495243137, Voice-Interface=0x0,
046569: Feb  3 17:56:57: //-1/4C84D3B79834/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
Dial-peers:
dial-peer voice 360 voip
corlist incoming toBRICall
description ** AGENT COR PEER **
translation-profile outgoing E164IncomingSIP
preference 2
voice-class codec 1
session protocol sipv2
session target ipv4:10.161.10.170
dtmf-relay rtp-nte
fax rate disable
ip qos dscp cs5 signaling
no vad
destination-pattern 166.
answer-address 166.
dial-peer voice 1 voip
incoming called-number .
dtmf-relay sip-notify
codec g711alaw
no vad
Thank you.
Best regards.
Marc
Hall of Fame Super Gold
You can see debug walking over all the DPs but what matters is that "right" one is selected.
Isn't that your case ?
Dear Paolo,  Peer ID 1 is used to route the call. What I don't understand, is that dialpeer 360 has longer pattern match and a higher precedence (I set Peer 1 preference to 3 afterwards). Router peer hunting is set to 0, so no reason for me for the system to use peer 1 instead of peer 360.  Also, when I remove peer 1, call is correctly routed using peer 360  Thank you for your feedback.  Marc
Super Bronze
Dial peer matching (inbound and outbound) has a list of attributes that are used in a specific order.
For inbound peers, 'incoming called-number' has top priority, so the other command you set are not checked as this 'incoming called-number .' matches any called number!
Destination-pattern is the lowest priority match for an inbound peer, and answer-address is lower priroty than incoming called-number.
See this doc for the process in detail:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic1
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Dear Aaron,
I know that, as you can see, my "answer-address" get a match and as told to Paolo, is up and functionnal. Do you have any idea why the router still goes thourgh and match a "destination pattern" peer instead?
Best regards.
Marc
690
