Musik On Hold ( MOH ) Problem
I´ve upgraded to CM 3.1(1) today - no problems till now exept the MOH Server.
When I make internal calls and hold the call everything works fine ( music is played correctly ) But when I make a call over the PSTN ( BRI ) to an 7960 phone I can´t hear any music !
Absolute silence - not even the normal beep !
Any idea ?
Markus
Re: Musik On Hold ( MOH ) Problem
Looking for the link(s) to the CM 3.1.1. Have tried the CCO section for Voice Software and I see the readme file for 3.1 but no upgrade file. Ideas?
Had the same problem and found out that MOH is only supported in location 0 (lan) right now. Will be fixed soon.
111
