MWI and serial integration
In a serial integration with NEC pbx how the light is turned off and on. How is the process works...Besides nec0000.ini file, is there any other file related to MWI settings....what is the function of avmci.avd file...If I can see PBX is sending on/off codes(j record using call viewer or hyperterminal) to Unity what happens when the codes are recieved through MCI link by Unity server...In other words I need to know what happens when Unity recieves a turn on code by the PBX. In some cases the MWI status is on in SA for a subscriber and the light is not on. In other case the status is off....Unity version 2.46 B135<br><br>Sean Poure<br>NEC-Voice Engineering<br>Sr. Aplication Engineer<br>714 4846275<br>
Sean Poure
1 REPLY
Anonymous
N/A
Re: MWI and serial integration
The actual packet definitions for lamp on and off are in the AVMCI.AVD file for this integration. That file defines the send and receive strings that are valid, so every packet to/from the PBX will have an entry in that file.
Unity will not do anything with an on code received from the PBX because there's nothing in the incoming packet section of the AVMCI.AVD file that would match.
If the sub page in the SA and the physical state of the lamp don't match, it could be because you need to run optimizer on exchange, there could be other sources lighting the lamp that unity isn't aware of (like the packets you're seeing from the PBX), or you could have unity attempting to light lamps for virtuals (extensions that don't exist in the phone system) which could cause the PBX to ignore lamp codes from unity due to too many invalid lamp requests.
Scott Morgan
Cisco Systems TAC
77
