MWI not lighting for some users
We are using Unity ver. 3.0. With one user I'm unable to save the change to "Use MWI for Message Notification". As soon as I try to save it, the check disappears from the checkbox. I'm also not able to add a MWI extension.
For another user, the above symptoms do not show up; everything appears normal, but no light when a message is left.
Thanks for any help.
1 REPLY
Re: MWI not lighting for some users
It's possible that there are two issues here:1) the weirdness on the SA and 2)lack of actual MWI on the phone.
#1 sounds like CSCdv69312
#2 wouldn't actually be caused by CSCdv69312
For #2, you could try the troubleshooting steps in this link...
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/tsg/tsg31/tsg_0500.htm
92
